Central locking....really weird.
basically guys, after a year i finally changed my central locking pump and now can lock both doors :D. however, my problem is i can stick it in the passenger side door and it'll open and close both doors. although putting it in the driver side door will only open and close the driver door..
theres obviously no leaks in the central locking pipes otherwise one side wouldnt work. any ideas?
cheers
  • Views 983
sound like the micro switch in the drives side door lock could be broken, turning the key triggers a switch.
It could be this or a loose/broken cable from the door lock to the car or beyond, might be worth dropping the lock unit out of the door and having a look for corrosion or damage to it.
Hope this helps :)
Hi, how do i get to the microswitch or whatever lock I need to get to?
Can you hear the pump working when you turn the key in the drivers side? If you can't then it could well be that side door key which requires attention/replacing, to do this, you would need to remove the door card. However, another common fault is a broken wire in the convoluted cover near to the hinge and check-strap, it is worth having a look at that before you remove the door card.You may need a 'c' spanner to remove the multi-plug (which itself is a possible cause of a poor connection.)
Regards.
I can only hear it work when i unlock it from the passenger side. The driver side door also unlocks but when putting in the driver door to lock/unlock, i dont hear anything, just the driver door being able to lock/unlock. the whole door card is completely removed anyway, so you're telling me to remove the whole handle and locking mechanism?
Regards.
Regards.
Going on your previous postings, I would suspect the rest of the wiring in your drivers door!! you need to either get a sparky to look at/repair the wiring in that door or get a new/replacement loom
ah okay then; cheers mate, ill let u know how i get on with that
I didn't say remove the lock and handle, what I was suggesting is that you remove and check the multi-plug (which also has the pipe for the central locking running through it) and check the wiring inside the convoluted cover. These are far easier to check than the bits on the lock, so have a look at them first.
Regards.
