Need a Mechanic for 6n 1.4 16v in Berkshire HELP!
Hi,
I have a polo 1.4 16v 6n which was my girlfriends old car. I've had a few probs with it in the past and so therefore replaced about £750 worth of bits (can list if needed) but it's still not running! I really need to get rid of it now so I'm looking for someone who fancies a little job for some cash to come and get her running or if they fancy it as is then take it off my hands. It's a shame because it's a minter with AC as well!
Anyway, if there's anyone who can help or you know anyone in the Berkshire area then I would be extremely grateful.
Thanks!!
  • Views 574
What kind of symptoms does the car have for not starting? for example, turning over not firing, or not turning over at all? and what sort of money would you be after?
Ok, here goes...
The problems started with the car not holding the revs when you put the car on full lock when cold and the car almost cutting out when you put the AC on and the fan cut in. The temperature gauge hardly moved either so I had the temp sensor changed.
It then wouldn't idle when cold - just kept dipping and cutting out until warm.
The throttle body was replaced and it started fine, however the idling was all over the place and I was told to have a throttle body alignment done. I had someone plug in VAG-COM and got it to a reasonable state.
The car was running ok except it sometimes had a fluctuating idle but I could live with that. We went away and left it sat for a week. When we came back it wouldn't start. We couldn't bump it or jump it. We finally tow started it but it just kept dying. I was told I needed a new distributer. I had one fitted along with new plugs and HT leads and it was fine. 2 days later and it broke down on the motorway after losing power. It started but would just die if you tried to put it under load.
A friend replaced the coil and ignition pack with a spare he had from his old Polo but it still didn't seem to cure the problem.
It's now just been sat in my garage and not touched for a few months but need to get rid.
Any ideas or fancy looking at it?
