4x100 to 4x110 wheel adapter
I've just brougth some weller wheel but wheel diameter is 4x110 and my polo is 4x100.
Does anyone know were I can get these type of adapters????
  • Replies 12
  • Views 4.6k
tried Wobble bolts should be ok ? . As you can use Wobble bolts on a 4x108 from a 4x100 pattern . *shrug* ;)
sure there not 4x108? as there quite common
Cheers for the advise ill check them out. :-)
They may be I dont no wether I'm measuring them properly, I'm measuring from bolt to bolt across but from the out and not centre is that makes any sence. :?
they will be a 4x108. can get adaptors but they will push the wheels out more so check they will fit
is this a wind up?
adaptors only way, but when you can buy wellers in 4x100, whats the point
no wobble bolts on 4x108 no chance because I have 4x108 and only chance is adapters.
I have one set of 4 if you are interested.
Thanks for all the advise guys, what type or name of adapter isit that i need?
Cheers.
pah my bad I'm thinking of mini wheels . 4x98 . to a polo hub which is 4x100 . Wobble bolts work then :)
Its all good mate, would you know what type if adapter i need ?
You will need 4x100 to 4x108 adapters. As Matus said above, he's got some for sale so I'd speak to him if I was you. ;)
