URGENT HELP NEEDED WATER LEAK
Hiya
slight prob got in car today after loads of bloody rain to find near the driverside foot well there is some water. i got carpet out at the moment so i can see. i have noticed that all the door seal is dry apart from the place were its leaking from. if this could be related???
otherthing i have noticed is the passangers rear foot well has a bit of water in it to. ??? and all the seal around door is dry apart from one place. near the door hinge. could this be related???
i have noticed when i was car water seems to collect on inside sill near were door seal is??
i just wounderd if anybody had any ideas or have had the same prob. i will say that when i got car partly resprayed i have had all the door seals out just wounder if i have nakked em when taking em out?
help
tom
polo 6n 5 door
  • Views 713
Mine does the same occasionally. I found it to be a split in the seal allowing water to run through the seal down to its join and onto the carpet. My easy fix. Super glued the rip and also the join. :)
yeah i have notiec the drivers side seal has a rip in it. will seal the bugger up see if tht helps
i aint seen on on passangers side but will have a look
thanks
tom
