polo car paint goes lighter as it's sprayed.
Hi, I'm new to club polo, please forgive me if I make mistakes.
We recently bought another 97 polo 1.4, 39K with a few small rust patches on the bottoms of the doors and sills, similar to the ones on the other car which I've successfully repaired. I used a colour matched spray can paint and lacquer. Both cars are metallic blue, 2 different shades though. On the current car after rust treatment, filling and priming I warmed the the hell blue colour matched spray can, I picked the smallest area for a tryout which was a good colour match so I carried on spraying light coats. After several coats I noticed that on one side of the car as the paint set it went several shades lighter. I decided to spray a sample on a piece of metal primed light grey, let it set and found it was a good match on all sides so I can only assume there's some sort of reaction taking place. Can anyone help please? Thanks in advance.
  • Views 1.3k
if its metalic could it be that you put too many layers on ?
2 should be all thats needed but then again they a rarely a perfect match
jamie
Edited by jamiet2
Sounds like you haven't shaken the can enough or the paint is being dryed to slowly and the mettalic is surfacing. Causing lighter(more silvery effect) appearing.
jamie
Thanks ....3 thin coats, last 2 coats went on and looked a reasonable match, after a few seconds went lighter. I didn't expect a perfect match from experience.
Thanks....shook can for at least 5 mins before warming in water and another couple of minutes before spraying.
Another thing, it will change slightly after laquer is applied. But you should be doing this straight after anyway, not waiting for it to dry fully.
Quite right.
After not finding any answer I decided to wet & dry down to the original paint. before doing so I took a couple of photo's then took the can back to Autoden who agreed the colour was wrong and gave me a full refund! I then went to my nearest VW dealer, after being told their paint would be the nearest match I could get I ordered the two pack @ £15.00 for 2 x 250 ml cans. I was told to collect next day, when I went back to collect I was told the paint hadn't arrived so had to go back next day which I did and was told no charge because of the inconvenience. I was amazed, not so much about the money but by the good will of such a big Co, Smith, knight & Fay. After giving them a big thank you I left, for a change with smile on my face after walking out of a parts place.
after spraying the base coat on I could see it was a good match so sprayed on the lacquer [straight after] I looked the painted area over next morning and this time was it was good enough and the lacquer still had it's gloss.
I'm not an paint expert but I'm certain the VW paint is superior to what you buy on the street.
Thanks for all your answers.
