100mm drop coilies compared to 120mm
I'm running 100mm drop coilies as far as i'm aware but I need the front lower. Like alot lower. I've got my sisters out, the bumpstops chopped to literally like 4mm and this is all I'm getting! My question is if I was to buy 120mm drop shocks, then do as I've done now... sisters out, chopped bumpstops and wound all the way down, would this get me lower?
Chris
  • Views 1.3k
what size tyres are u running? helpers out will normally send them plenty low enough - unless its a 16v in which case the driveshafts will often catch the arb (i think)
215706_139725472766462_100001870315207_2
I'm about an inch lower then that at the moment, But I want the wheels tucking, I'm running 165 45 15's
i should imagen so dude, but it'll ride like shit. thought about doing the turrets? you notched aswell?
I've found out I am running 120s!!! :/ I'm thinking about it Rob, but I must admit I've been looking into narrowing the front end, ha! In the short term I'm thinking of just raising them yeah, Anyone on here done it? My drive shafts are miles away atm, But I'm curious if I raise the turrets that the inner arches may need tubbing?
i shouldn't think they'd need tubbing man, theres loads of room under 6n arches without the liners in. if you've got option to, you might aswell do the turrets, even the you get some of your suspension travel back too
good point mate, I'll get onto it in the week, should't be that big of a job! he says...
