6N2 Polo 1.0 Parts.
The parts below are from a 2000 VW Polo 1.0 with 68000 miles. Engine code ALD. Parts may fit other models and cc of polos, lupos etc. All prices are plus postage unless you want to pick the item up. If you are interested in a part and need more information, pictures or postage quote, then please get in touch.
1.0 litre short block, good condition ALD engine code 030 103 019 £120 (Postage available)
Thermostat Housing £10
Power steering pump 030 145 157 D £25
Exhaust manifold 030 253 031 AC £40
Exhaust manifold heat shield (has a few dents) 030 253 041 L £5
Coil Pack 032 905 106 B £15
Timing belt lower cover 030 109 127 M £5
Timing belt upper inner cover 030 109 145 AH £5
Timing belt upper outer cover (very slight damage) 030 109 121 K £2.50
Timing belt inner rear cover 030 109 170 D £2.50
Front engine bracket (030 145 169 H) complete with pully/tensioner £20
Engine bracket (cam belt side) 030 199 275 B £10
Crankshaft pulley 030 105 255 D £10
Plastic water pipe that runs behind engine 032 121 065 D £5
Fuel rail (030 133 319 AA) and injectors (030 906 031 J) £20
Oil separator 036 103 464 G £10
Inlet manifold (030 129 711 BP) complete with throttle body (030 133 062 C) £45
Inlet manifold on its own £20
Throttle body on its own £30
Clutch, pressure plate and flywheel £35
Steel plate between engine and gearbox £5
Edited by mk1wideboy
  • Views 724
btt
bump
