Smoothing 6n2 Door Strips
Had a look using search but can't find what i'm after. I was to remove my side strips and smooth it all off but what's the best way of filling the holes? Do i need to fibreglass behind the holes first or is there a filler that will just fill in the holes and stay put without any support from behind?
Cheers,
Fred
  • Views 770
Popular Days
countersink the hole and drill very small holes around so when you put the filler in in mushrooms behind to keep it solid make sure you give everything a deep key so it doesent fall offf
