quality of engines
myself and a mate are both rebuilding two new engines we have for our cars, mine being a 3F and his being a 1.8 8v for his golf
were basically doing them both at the same time, both heads are off and we noticed a difference in quality of the finish of the casts of the head and block like castings marks, flash and finishes like on the edges.
the 3F was manufactured in germany and the 1.8 was manufactured in mexico. the 3F is alot better finished as the casting marks have been well finished and the edges are crisp and smooth with one or two ridges, were as on the head that had been manufactured in mexico the casting marks were alot more visible larger and sharp, and along the edges were just ridges, sort of like a hacksaw blade - just not as sharp
has anyone else noticed this? does anyone have an engine that has been manufactured anywhere else?
should this quality of casting be thought of in terms of cost??
have a look at your engines and see where it was manufactured and the quality of casting/finishes
taa
cam
  • Views 651
Popular Days
The metal itself is the factor for me,it varies greatly and age is as much a factor as area.
I've had a poor aluminium with a German head and better quality stuff in the shape of a Polish head.
The aluminium cylinder blocks were very well finished,but then you only find grinding marks on the iron ones. Ally ones can have inconsistent excess milling marks though,as with two i have. I've only really found flash around date stamps on iron ones,though some cast can be a little out of shape like the strengthening ridges in one of my AVY blocks,which looks like its made of plasticine..
I haven't taken much notice though,given the amount of these engines I've owned/stripped/rebuilt. I dont know where half of them were made. I'm not a fan of quality control as long as the part does its job and doesn't fail as a result of it being poorly built - including poor materials like the over-recycled plastics Valeo use,resulting in their light lenses failing in what i personally consider to be prematurely.
