Anyone know anything about corners?
DeathFromAbove, consider yourself schooled :lol:.
schooled
:nod: And a noble pupil, i think :thumbsup:
But we're all schooled daily,apart from fools. Wisdom is something to embrace and collect,not be embarrassed about - especially learning the easy way (which can be hard to do!).
The day i stop learning..
  • Replies 59
  • Views 3.9k
That does look like a nasty bend. What happened did it understeer or did you just not steer enough?
That is well fucked mate,you should know the front wheel is pushed like 2-3 inches back as a result of the ARB being pushed back and the chassis leg is split right open.
The ill-fitting door suggests the frame has stretched,and that's real bad.
It'll take a re-shell or proper jigging to sort. The latter will cost many times the worth of a shell to do properly,and even then it will never be right.
Any chance of getting the corner on a Google earth screen print? I'll show you the warning signs you've clearly missed..
also known as lines in the middle of the road... :roll:
It's quite simple, the road markings (long dashes in the centre) mean "Hazard ahead" slow down expect a sudden change of direction!
But if you had followed the great Roger Clarks advice, you could see the the tree's on the outside were going around 90 deg+, so you should of slowed to an appropriate speed!! so I suspect you were doing over 30mph as even with the Polo's lack of handling, I very much doubt @ 30 mph or less you would of drifted into the ofside lane! unless you had mittigating evidence, like oil slick on the road, bald tyres! suspension lowered beyond manufacturers limits or total brain failure!!!
or lack of a steering wheel....
Or lack of driving experience!!
I know this corner - it's very close to where I live
http://maps.google.co.uk/maps?hl=en&ie...p=11,54.03,,0,0
The first time I found it was at night in drizzle. I can sort of see how it caught you by surprise, but in honesty it's a 30mph limit and the corner should be taken at 20max so it wouldn't have taken too much to slow down in time had you read the corner. There is a warning sign as you approach from the east and north, and chevrons on the corner if you approach from the north.
Lesson learned I hope.
When you come to break it, send me a PM ;)
started to turn the corner and some woman was cutting it slightly, seeing as i was doing almost 25 which was a stupid idea i started to pump the brakes but the wheels locked up and skidded into the middle of the road
yer it was getting dark and the road was wet when it happened to me, probably put it down to me not being experienced with corners like that.
and i don't think the lesson could have been taught any better.
and will do man. you interested in parts or want to help? :lol:
Possibly some parts - but depends on your plans for the engine (is it a 1.3?) as I know you were looking to stick it in something else?
I'm quite occupied with work generally, but if there's a spare morning sometime I don't mind popping over to lend a hand
nah this is the 1.0L version, hoping to stick it in a mk3 loon after i've cleaned it up.
depends on whether i get some good offers for the engine though, which i doubt cuz the radiators punctured
and yer that'd be great, won't be breaking it for a little while yet though but i'll pm you when i plan to
cheers man
