Heater resistor, capacitor size?
Hi y'all. My heater fan only works on speed 3! Have checked connections and the power split from the switch is ok. I removed the resistor block to see that there is a small capacitor fitted under the block. I think this capacitor has failed. Does anyone have any idea how to fix or what replacement capacitor to use? A new reistor block from VW is £40!! Cheers
  • Views 643
Would've thought that the cap is just a filter for the motor when you adjust the speeds? Like, The cap will probably run in parallel with the motor so that when you change speed (hence voltage/current); the motor gets the change more smoothly, there will be less arching across the switch, etc.
Doubt a cap would fail; it'll be the resistor block tbh.. Just test it with an ohmmeter? Then get one from a scrappy!
i bypassed the resistor with a couple of wires, then bunged a blade fuse in between. worked a treat.
i noticed the third speed setting bypasses the resistor.
