Scuttle Tray Cover
I want to make a scuttle cover all the way along the front of my mk2, not just the portion the OEM part covers. Anyone have a template? Someone was selling carbon fibre wrapped ones, but they are a bit flash for what I want. Looking for body coloured fibre glass, or possibly polished stainless. Anyhow, I need the template first
  • Replies 14
  • Views 2.3k
Cardboard is your friend!
I'm lazy :lol:
id be intrested too...but how can you make it hook over the lips so the water is channeled away?
Theres some for sale in carbon vinyl stuff, DKnight is selling um
Expensive though, however id love the template to get my own made. I don't want fake carbon vinyl stuff. And no way was i going to pay the £65 (i think it was) for a piece of shaped plastic :lol:
Looks like I'm going to have to do this myself then. I would most likely get it done in fibre glass to keep weight down, with two access holes at each end to get to battery/fuse box.
Would anyone be interested in one too?
BTW B-shaw, i have that pulley alll packaged etc, but i deleted your address. Just found it knocking about the garage the other day. You still want?
might be intrested depending on how it goes
id cover the battery so it helps keep the battery tray dry and rust/leak free
do you plan to make it fit over the lips along the front and rear or just a flat plate
just do what I'm doin relocate battery in boot fuse box under dash board and remove the heater matrix fuckin thing never works anyway :lol:
Shit load of work when you can simply just cover it :lol:
I like my heater, mine works really really well :)
I'd be interested, although i might have a bash at making my own. Just making the template is the hardest bit. I'll get a company to cut it for me, be perfect then.
As for mounting, i reckon ud need to make some sort of a bracket somewhere for it to just rest on. If you make it a tight enough fit, putting the rubber seal back on the scuttle part will be enough to hold it in place.
Prankstar, PM incoming
Edited by B-shaw
The battery will be covered, will just have a 'trap door' type thing to allow access. Mounting will be the most difficult part as I'm trying to keep the bay clean, I don't want nuts and bolts sticking into it. Brackets on the back of the inner wing (if that makes sense) may be an option. I'm currently trying to sort the scuttle, wiring, hoses etc at the moment. Going to pop up to a guy who does fibre glass in a few weeks, so I'll update with progress when I have some. Will probably try and make it slightly sloped to have the rain run off too.
Don't really want to relocate battery as I want easy access to it. Plus it means running big wires through the cab etc, dont want to lose the boot space, and like to carry a spare wheel too! Seems like too much hassle. Want my heater too!
Btw, anyone know if you can still get the rubber grommets that go from scuttle to engine bay at all?
Ill put up pics of my setup later. I have a full carbon fibre scuttle cover with a trap door battery access. I can take measurements also if you want wont be till sunday though.
I bought one off DK many moons ago... It was a great fit.. Aluminium I think with a black vinyl finish.. Was really nice..
Realistically after buying all the required parts/tools you'll be half way there to the cost of DK's.. Then the ball ache of labour: measuring, making one, fitting it, realising you've fucked up and have to start again. I know what I'd be doing..
Yeah, i see your point. I have most of the tools, and a mate who does fibre glass. I'll weigh up the costs, but i know what i want
Stumpy, that'd be great if you could get pics up
Yes stumpy, that'd be ace!
just woundering but has anyone thought of making one out of acrylic ??
