6n gearbox code 1.6
Hi were would u find the code for my 1.6 gearbox I found one 3letter code not sure if it war I'm looking for. the code is SET
I'm after the code to get new bearings for the diff do u have to use vw ones or will any bearings work ?
  • Views 1.3k
The code will in one of two places, either on the data sticker in the boot
Or on the gearbox itself
Hi thanks for the reply will be very helpful :)
As mentioned, easiest place is in the boot. If not, it is stamped/printed onto the top of the gearbox by the clutch inspection hole, but it's not as clear as that ^^^
May well be an EQY in your car.
Ok thanks I had a look in the boot I wanted to check the box was the same so I'll have a scrub up around that area thanks guys
To bring it out on the top,i find a bare stanley blade is best - just hold blade-down and scrape back and fourth until it comes out.
You can use up any old blades which have blunt tips,as this only really uses the centre inch of the blade.
It might be as well to use genuine VW bearings, as it is possible that the bearings in your box MAY be of 'three naughts' (three dots) tolerance, which may not show up on your original bearings, so if you merely go on size from a bearing catalogue, there is a risk that you would have the wrong specification.
'Three naughts' or 'three dots' bearings have greater than normal internal slackness and are used where the bearing is a tighter fit than 'normal', either in its housing or on its shaft.
Regards.
