weight...
(this is not a post about how fat i am)
Just wondered how heavy the average MK2 bready is?
Tah
  • Replies 15
  • Views 1.6k
ah right, i wasn't aware of those.
Tah!
no way are they over a tonne I've heard around the 750 kilo mark wouldnt say much more than that tbh
its around the 750-850kg mark
alright tah =]
wasn't sure whether to use my dad's posh jack cos it's 1.25 tonne max.
it was fine =]
Yep.
To be honest, if a jack won't lift that up, it won't lift anything up.
well it's for my dad's caterham, which doesn't have much to it anyway, so pretty light =P
If you think about it the jack doesnt take the whole weight of the car only up to half of it so you could prob lift a fairly big car with it I reckon :)
depends how u jack it up really, itl be fine tho
thats the coupe weight :)
They vary from about 715kgs for an early low spec 1.0 4sp breadvan, to around 775kgs for a late full spec coupe.
Coupes are heaviest,with 5sp gearbox and sunroof adding in.
I got my early tin top coupe down to the magic 690s once,but it took an aluminium cylinder block to do it. And id have been stuck with a flat tyre,too.
my god that must have been a rather... adventurous... car to drive at 690kg mikey :unibrow:
Made the steering more responsive,not really worth doing otherwise,especially given the hassle it was to use it for the 1.6 AFH.
Iron blocks are better,so I've gone back to iron with the vvt head.
Anyway,some are surprised that saloons are lighter than coupes,especially when hatches are lighter still. With the hatch,its likely that the narrower wheels were included in the figures,but that wouldn't be enough to change anything (Its actually a piss in the ocean regarding the overall range). I doubt the framework for the third door could be the only factor.
Some sources have reported bigger outer front C.V joints on the coupe - the only evidence I've seen of this myself was in the form of C.V boots i bought that were too big for the facelift model breadvan ones i have on my coupe.
There's an awful lot to differ early and late models too - '82 and '89 models actually shared surprisingly few identical parts. Changes like the rear washer bottle being scrapped and different design of steering column are common knowledge,along with different size fuel tank and different front suspension legs. I'll leave out the obvious with the engine.
Less known is the styling crease around the coupe rear side windows being softer from '86 and the rear arch extensions only getting bumper recesses on some models,very little got away untouched and that includes virtually all stages of metalwork from the spare wheel bracket to most panels.
Even an '88 bonnet is different to an '85 one. I'll let you find the difference.
So weight, i expect, is not varied on any one big thing, but a wide number of things. Even though those differences are quite consistent of their era.
