JVC DOUBLE DINN HEAD UNIT
hi guys selling my head unit because I'm getting a mk2 golf and it wont fit in there without making unnecessary cuts to the dash
JVC KW XR411 DOUBLE DIN CD RADIO WITH MP3 CONNECTIVITY
The JVC KW XR411 is an RDS equipped USB/CD receiver that will keep you entertained on the longest journeys. The KW XR411 with USB connection you can listen to an iPod for instance or plug other external sources into the 3.5mm stereo jack socket on the front panel.
FEATURES & BENEFITS OF THE JVC KW XR411
Powerful amplifier - MOS-FET 4 x 50 watt
High quality sound - 24-bit DAC
Adjust centre frequency - 3-band parametric iEQ
Connect an USB device via front USB port (MP3/WMA)
MP3/WMA compatible with ID3/WMA Tag (CD/USB)
Radio data system tuner
Advanced tuner - HS-IVi tuner
Loudness control
2.5V line and subwoofer output level
RCA Pre-out terminal (Rear/Subwoofer)
Subwoofer Control
Connect an MP3 player via front Aux-in
Steering remote control ready with compatible adaptor
http://www.halfords.com/webapp/wcs/stores/...yId_165474#dtab
RRP £229
asking £120 ono
cheers xx
Edited by Larry6n2
  • Views 364
bump
open to any offers
you able to post yeah, if so how much?
does it come boxed and with all the things included mentioned in the link you provided from halfords?
i can post it for 110. its practically brand new. doesnt come with the box as unfortunatly my step dad binned it :'( .. if you want it to fit a polo then ill throw in the nessassery leads and connecters. ill even throw in an aux cable so you can put your ipod straight into it when it turns up
cheers
laurence
