Window tinting
Anyone got a guide to window tinting, iv more aless got the equipment but has any one got a best way to do it? As there a pain when the bubble! Lol
  • Views 615
Popular Days
I did mine almost perfect (no pics as I've since removed em)
I found it easier to spray the outer of the window with a fine mist to and place the film against the window (the part that goes against the inside of the window facing you, use a good quality squeegee (sp?) and start from the centre out getting it flush against the window.
Once done use a sharp blade to cut the film to the same shape as the window.
Once you have your cut out climb into the car and same again really, spray the window with a light mist and start to peel the film and apply the top edge first peeling away slowly and carefully using the squeegee as you do so.
When all the backing is off comes the hard part, using your hands manoeuvre the film to position on the window. you should find you have more film than window due to the seals been in the way, use the squeegee again to push the film under the seals. Once its all in place go to town using the squeegee to get all the water out, starting again from the centre to the edges been careful not to crease or tear the film.
It can be fiddly and a pain and if you can take the glass out to do it its an easier option. You can supplement the first step and use cardboard for a template.
Check youtube as well as it has some helpful guides. The main problem i had doing mine was the daft plastic squeegee tore parts to shreds on my first attempt!
