Red 6n
car is lookin well nice mate wheels go well with it
Cheers man
  • Replies 507
  • Views 58.2k
Went out and got some more pictures today :)
Looks mental man :) Just that poor sill :( haha
Keep up the good work!
Looking well nice! Which rear bumper is that?
nice photo!! my new wallpaper!
I know, lets the whole car down :(
But thanks man :)
Cheers, and 16v man :)
16V..... Needs a 8v front i think ;)
I'm thinking the same thing, next month i'm gunna get the 8v plate recess smoothed, then go about getting the gti splitter on the 8v bumper, and it will go back on :)
Wow thanks man :-D
not low enough yet ;)
love it on the white wheels, looks pimp! photos are nice too
It can go lower, but I'm not going to, not worth ruining my sub frame for going an inch lower.
And I've sorted some 195/45s lined up for the front, so once I get them on, it will get rid of the arch gap, and i can go a tiny bit lower without the bottom going lower... :)
But thanks man :)
car looks fucking SICKKKKK! I'm maxed out with a notch too and my bumper aint as close to the floor as yours!
have you taken your helpers out?
and the cars lookin mighty low :lol: keep up the good work :-D
yep, helpers came out LONGG ago! ile take a photo tomorrow and try upload it cos I'm jelous :(
Thanks man.
Are you on 14s? I couldn't really get that low when i was on 15s.
Cheers dude
Had a spare grill and badge, so I thought i'd spray it black to see what it looks like..
Also thought i'd colour code the door handles, only did one as I ran out of time. Also could only get mars red as they didn't have any flash red. It's not exactly the best colour match but it doesn't look too far out from a distance. Any ideas on how to get it a bit darker?
I went and got a 16v rear but sticking to 8v front, for now ;) Badge looks good by the way :)
Yeah that was my plan but the front popped up cheap so i thought i'd get it, and thanks man :)
Just wind coil all the way down man.. if your handy with toolage change a sumbframe is nothing.. there cheap aswell ;).. Sick whip eithier way
Nah i'm good thanks, would rather have it an inch higher than ruin my subframe all the time.
Also get some pics of yours, wanna see if it really is the lowest 6n in london...
Cheers though
Ok fair enough, check my thread its mostly words but be assured I'm not gassing if it's not now it will be..in south east london anyway cause london is a big place. and i know there are cars hidden everywhere, could be wrong... just an in joke with my friends really... and again your car looks great mate!!!
Right then, snow pictures :)
I'm aware of the reverse rake and it sitting like absolute shit on the front, need these new tyres so bad!
So I just drove down the road, and it turns out my brakes decided not to work... When i pump them they stiffen up, but when the cars moving the pedal goes straight to the floor, and just about stops when my foots right at the bottom. There's fluid in the resevior and the brakes were bled and had new fluid pumped through about 2 months ago.
It's weird because i drove my car off and back on the drive about an hour ago and the brakes worked fine, but now they dont?
The rear brakes have been squeaking for a while but they have still worked fine up until now.
Any ideas from anyone?
Edited by AndyBMX
Have you checked your disc/pad wear? That might be your problem? If your pads are really low the further you have to push the pedal, the more the piston is pushed up against the pad. Often meaning pad wear is low? Also the squeal from the rear brakes might be your handbrake shoes are F*cked. Just double check them.
Good tip: Only check 1 side of the car regarding brakes, to save time because pad wear is normally equal. (advised you should check the other side too but up to you)
Hope this helps
Carter
Hope this helps
Carter
Nah it's not the pads they were replaced not long ago and have lots of life. I'll check the handbreak cable though.
I'm going to bleed the breaks again when the snow goes.
thanks for the help though :)
Not to worry. Yeah bleed them for quite a bit see if there any air in the system (1L). For the handbrake cable, no more than 5 clicks is perfect :D But it might be worth checking your drums inside.
(If they are hard to get off after undoing the two bolts, then your handbrakes binding/ on its way out)
Carter
Carter
Yeah I'm going to bleed them tomorrow morning and see if it helps. Yeah I remember that last time I took my drums off they were a right fucker and took some serious effort.
Thanks man.
No worries, Hope you sort it out and hope I helped
