long distance
okay, i'm thinking of going to anglesey this summer in my MK2 bready.
it'll be about a 3 hour drive, just wondered people's experiences with such journeys in MK2s?
i'll be on A roads pretty much all the way there, so won't be going much above 60.
likely to kill the polo?
Ed
  • Replies 17
  • Views 1.8k
omg, If you think leaving your postcode is going to kill the polo your wrong.
She'll be fine. :thumbsup:
haha.
well, i'm on classic car insurance so i have really limited mileage and never drive much longer than half an hour.
i think the longest drive i've done is picking it up from bristol, when dad drove it at 100mph most of the way home... surprised it even got that fast! probably didn't do it much good though =P
Your on the A5 mate theres a chance you wont be doing below 60 on most of it :lol:
Second you pass the tight bends at Llangollen its foot down, long straights, sweeping bends, only a few slow technical sections.
A section of it makes up the bottom of the Evo Triangle and that stretch is done flat out. :lol:
Used to use my coupe s for work, couldn't fault it.
drove mine from london to north wales no probs
okay cool =]
not that i don't trust it's reliability, it's never broken on me, i just want to be sure.
tah =]
used to drive from carmarthen to bangor twice a week, still drive up for meets every once in a while. lol
i do double that in mk3 (hardly mechanically different) at least 6times a year sometimes more. Even done one the day after another. It will be fine just make sure your tyre pressures are good and the oil is topped up and your off
I drove my old mk2 from brighton to birmingham and back in the same day with a fucked headgasket, luckily it was cold and snowy so it kept things cool.
I drive 25 miles to and from work every day in my mk2, 6 days a week. I also do long drives to devon every now and again, as long as you're looking after it it'll run forever..
mk2breddy shere be fine just make shore you keep up to date with the services
i didnet change my cambelt it done nealy 60,000miles but snaped on a long drive was ment to be changed evry 40,000 ended in bent valves
Not too much of a difference, but i use my MK3 for dominos deliveres 4 times a week, and any other day I'm driving a lot.
Copes fine so long as you take good care of your car :-) .
I used to drive my Breadie from Bala to Redditch twice a week (sometimes 3) to and from work for four years. car never missed a beat. The secret is to keep it serviced and if anything isn't quite right, fix it there and then rather than waiting for something nasty to happen.
U will be fine mate, cars let u know ( generally ) when some thing is fucked and dying so as long there isn't a whining pump or slipping clutch.
Mk 2's are gd simple cars
If you are worried take some ht leads, plugs, coolant, alternator belt, etc just general things that u fix at the side of the road. Wouldn't worry mate, it will give u plenty of warning if it's dying.
Depends on its state. If the head gasket's on its way out,it hasn't had a new cambelt in six years and there's no oil in the gearbox you may wanna consider a few precautionary measures.
But if its generally in good health,you may have a similar experience to me,only in miniature - when i first had my '88 it was completely standard,and i used to drive over a thousand miles a week in the thing,with non-stop journeys to Aberdeen and back from here in Buckinghamshire being the bulk of it.
Sometimes in monumental weather conditions.
cool, ill check everything out =]
Moreorless every trip in my mk2 is a 100 mile or more drive, 'cos the shows are so far away. In 2006 I drove it to belgium via the eurotrunnel for the last VW Mania. :) 900 mile round trip!
