How to take out sun roof cover
Just wondering how to take it out do u just take out the 6 bolts and take all of it out and disconnet the water tubes?
Because i would like to retrim that aswell as the pillas and linning :D
Thank you
  • Views 784
it slides back towards the boot. there are 4 plastic clips that stop it from sliding, pop them off and keep on sliding it. Simple as that.
o rite i take it the clips are at the back of the cover nearest to the boot ?
slide the panel back as if you were about to open the sunroof and you will see two black plastic clips that stop the panel from going back any more. They pop off and the panel can slide a bit further until hitting two other clips. Pop them off too and the panel should slide right out.
Ill give it a go thanks :)
