mk2 bumper removal
silly question for some but how do you remove them
as I'm going to give them a lick of paint :)
cheers
  • Views 1.8k
must be the easiest car ever to work on
take a look inside the boot..theres 1x bolt each end 13mm size
same at the front although its a bit fiddley to get at , i take the grille off and use a 1/4" ratchet ..2x13mm on the front
sorry to hijack your thread but how do you remove the plasic front bumper from the bumper bar? only that I've picked up a replacent for mine and I need to get the plastic off so I can fit the mounting brackets
not easy...look at it and you will see theres plastic tabs clipped into the metal , you need to force each of those down and pull on the metal , quiet tricky
to take the front bumper off, i think i got under the car and did it from beneath.. not so easy if you've lowered it though =P
