Alternative fuels. (Anyone else?)
Hey.
After a long and drunken coversation last night with a friend who runs his fleet of classic mini's on a ethanol mixture i think ill give it a go with the bready. :)
I know i have to change all the fuel pipes and what not, but its likely to save me money in the long run with a good supply of E85 local to me.
My question is, anyone else running E85 in there polo's that are none flex-fuel cars?
Ill keep yah updated! :)
  • Replies 14
  • Views 1.4k
We've used ethanol in the golf a few times, just to tide it over until we can afford petrol.
Also not ethanol but my dad uses veg oil when the diesel prices get stupidly high or when it is a good saving like the veg oil is on special or just cheaper :)
Edited by DavidTiger
Brother uses pure new veggie in his mk2 golf van :) Runs perfect and at £2.97 for 3 litres its alot cheaper!!! :p
where would you buy ethonol from?
another important thing to remember is that all forecourt fuels in the UK contain at least some ethanol usually less than 5% so pretty much all cars are capable of running on ethanol. apart from fuel pipes you'd need to make sure the washers and so on in the carb dont get eaten by ethanol, it is usually a good idea to get a second carb and soak it in ethanol for a week to check then change the affected bits for synthetic bits then attach that modified carb to run on the ethanol. I'm no pro but if that info is followed it can allow you to run E100.
I destroyed a set of bike carbs on the stuff, and it boils my piss to think the petrol companies sell us fuel deliberately contaminated with this shit.
I dont even wanna get started on it, just to say that it aint good for any carburettor.
Local friend travels up towards preston to get his methanol and the company he buys it off sells ethanol aswell so if i pay a small cut of his fuel bill he brings some down and stores it. He does a run every month so its a good supply :) :)
I've not got a carb on my polo so it should be good :/ I hope :)
Ill see what happens and update you asap :)
Edited by Toptrumps2
what are feul inlected polos like running on ethanol ?
Ill let you know once i run it on the stuff for a week or soo, i think it will clear alot of crap out :)
Have tried methanol, but you need to remap to suit. Then your fuel economy goes down the spout, so you lose any financial benefit from the cheaper fuel. Fuel lines, pumps and injectors should be changed too. Much easier to buy an Aquamist kit and inject it with that in addition to petrol though - can capitalise a bit on the performance advantages of methanol without too much arsing about...
with ethanol and chip fat you can take advantage of the government legislation that means you can make 2500 litres of your own fuel tax free each year. so taking my 6n2 as an example where I regularly get 32 MPG (majority is town driving) and it has a tank of 45 litres or approx 10 gallons and 2500 litres is around 55 tankfuls so with a tank getting me 320 miles, 2500 litres of E100 will get me 17600 miles. that is alot more than I require, so then it is tempting to buy a second car to help me utilise that extra ethanol as you can't sell it on. you may ask why haven't I tried this? I don't have the time or space to make the ethanol still to distill my own ethanol, and I'm not sure how the 6n2 will run on ethanol.
You'll get 17,600 miles on petrol, but not on ethanol or methanol. Something around 20mpg would be more likely.
You need to run a much richer air/fuel ratio on the alcohol fuels - stoichiometric AFR on petrol is 14.7:1, ethanol is around 9:1 and methanol is something like 6.4:1!! Given that a boosted motor running on petrol is running leaner at full boost/throttle than you would at cruise/light load on ethanol, it gives you an idea of the consumption differences.
this is also why I haven't done it. Because I don't know too much about it.
why can't it be as simple as shoving some filtered chip fat in.
I'm quite glad i posted this on here before i put it straight in, ill have to work out some sums :) Didnt even think of consumption diffrences and now i got a feeling its going to weight out the "savings" :/
Aquamist kit sounds intresting ill look more into it :) x
