Correct procedure to fix deep flaky car scratches using touch up paint brush?
Whats the stages in order from start to finish to fix deep wide flaky scratches located on the edge on the front bumper lip? My bodywork is metallic paint.
Is my front bumper made out of fibregalss or plastic? I know its not made out of metal.
grey primer and laquer came with the paint i bought. Can i use grey primer as a filler to fill the scratches or do i have to buy a seperate body filler?
Whats best, wet sanding or dry sanding?
How do i blend the new touch up paintwork with the rest of the body paintwork so it doesnt stand out?
can laquer be used as sealant?
What other products i need to get from halfords to give me an idea on what i need?
thanks,
  • Views 822
sounds a bit much for a paint brush job
it cant be simple as getting a brush and painting over the scratches.
the scratches wont be filled, the paintwork will stand out from the overall bodywork, and the surface wont be smooth.
Cars are expensive so i wanna make sure I'm doing it right and not mess it up.
