mk3 Polo Dash Change help
Basiclly I'm looking at changing my dash and i was wondering are there any speedo clocks which plug straight into the mk3 loom ?
cheers for the help
  • Views 609
TBH, you're unlikely to find much that will plug straight in, unless you pic from VAG group cars. Even then you might only be limited to cars of similar age such as Mark2 Golf, Passat, etc.
I'm not saying you can't fit any clocks you want, but you'll have to be handy with wiring diagrams and a soldering iron. For example, youngprodigy has successfully managed to fit Audi TT clocks into his G40, but that was most certainly not a case of 'plug & play'!
