Removing side repeaters
What's the best way to go about removing the side repeaters on my polo? Can I just get fill it over, rub down and paint? What should I do with the wires that are left behind? just leave them? :?
  • Replies 13
  • Views 1.6k
I would say the best way to do it would be to spot weld a metal plate on the inside of the wing and then just filler etc the outside as the filer may crack if covering a empty hole after a month or 2.
With the wires i would say just wrap them in insulating tape and stick em to a panel.
This is how my boot was done a similar process
Edited by Josh Bmx
will need t weld the hole up and then fill and paint or the filler will just flop out..
the wires behind you will need to put end blocks on them and wrap them in electrical tape and make sure they are out the way.
Cool cheers guys! Will do... I know someone who can do the spot welding.. will get on it the next few weeks!
You know the legalities,yeah? Just it hasn't been mentioned yet that you'll be breaking lighting regulations for your car,and subsequently fail an MoT.
Just for you Mikey http://www.legislation.gov.uk/uksi/1989/1796/schedule/7/made make up your own mind :?
well I didn't think it would be a failure... I've seen many cars without side repeaters.. surely they cant all fail :-(
I know 6n's can get away with it as the front indicators are visable from the side of the car when flashing but other models I'm not sure
Have a look at the link I posted and then if you can work-out if it's OK I thought it was OK as the front indicator comes so far around the wing, but those reg's seem to suggest that the side repeater must be visible to a 60deg angle behind the light???? but like most things it all comes down to pc plod or the mot testers interpretation of the rules!!
Yeah I had a quick read through... I looked at it as a failure without one, which is pretty rubbish... my mot test centre are usually pretty decent so maybe they wont notice.. my last car had colour coded side repeaters and you couldn't see the blinking.. I almost think if it's not there to test, they cant fail it :oops:
I know what you mean, if it's not there it can't be tested so can't fail! but before the emission tests were introduced, in theory you could push your car into the testing bay and still get an MOT!!
I've just got some blue side repeaters, blue front indicators and blue rear lights, but they came with the TUV approval paperwork, so come September when my MOT's due and if they fail on those items I'll wave the TUV certificates to prove they are legal!! It's almost getting to a point that you need to have a lawyer with you at all times to claim "it's infringement of your human rights" to not modify your car!!
That's an argument for the MoT bod,not myself.
Possibly an easier one to get around on the facelift models yeah,with the corner indicators. Wouldn't wanna try it with a pre-'90, as the indicators cant be seen from the side at all.
Its a load of bollocks from a safety point of view anyway, i recon. You dont move over unless you know its clear,i look over my shoulder but even without doing this you've gotta be just plain ignorant to miss a car bedside you,so apart from helping people shirk their responsibility i dont see the point in side repeaters.
Either way, with things that aren't legal requirement on any given car (such as rear wipers or fog lights) they have to work only if they're there. Remove them,and you get a pass.
But with dated items fitted from factory,such as rear seat belts on cars registered from 1985, there's no getting out of it.
Bit of a grey area with the repeaters though,as said by others above,sometimes the front indicators are considered satisfactory for the job if they're visible enough from the side.
Whether yours are or not,well there are people here who will be interested in knowing the outcome!
As you say Mikey, it's a bit of a grey area, but those reg's seem to indicate (no pun intended!) that all vehicles post that date have to have side repeaters, the car was given it's certificate of compliance with the repeaters fitted as required by the various reg's, what confuses me is that they show in the diagrams the light should be visible from an angle of 60deg behind the light??
Rear wipers and front fogs are not required by the construction & use regs, but if fitted should comply to light alignment -3%(not an MOT testing requirement) and the rear wiper is not required at all! working or not fitted, should not be part of the MOT
Maybe I'll risk it... what the hell I'll do when they fail it I'll never know!! It is pretty silly though, I understand the safety aspect... but I can't think for the life of me, anytime when I've noticed someone turning by looking at there side repeater, I'd class it as dangerous to look solely for that! :lol:
It's never made clear to anyone how these tests work really, it always goes on the tester...I looked back on previous MOT and its failed on missing numberplate bulbs... I've been guilty of going to a mot with one numberplate bulb out on my vectra (lapse of concentration pre mot checks) and they replaced it and carried on with the MOT... some places just don't give you a chance though!
