gearbox mount hole lost its threads
Bit of an issue, when fitting the rear gearbox mount to the chassis the thread in one of the two holes stripped so why are my options for sorting this?
Only things I can think of are tapping new threads in for a bigger bolt, or cutting a hole in the inside of the floor above it so I can remove the nut from the top of it and weld another one one then patch the hole up.
Obviously I'd prefer to just tap new threads as it would be easier, but what have other people done to fix this issue? Any other ideas? Surely some one else must of had this problem in the past?
  • Replies 8
  • Views 1.3k
Rivnuts possibly be your easiest option, can get them from ebay.
Duno mate just had a look at them and they don't look like they be much good for my needs, they don't look like I would be able to remove them as and when I need to drop the engine. Ideally I'd rather do a permanent fix while the cars off the road rather than doing a quick fix if I'm honest
Cheers for the advice tho mate
Edited by McLOVIN
I don't know whether you saw my thread a few days back (I broke one of the threads on the arb mount) and I've decided that rivnuts are no good for any application like this. I wouldn't trust them. If I was you, and I had the resources and the time, I'd weld it like you suggest. Thats what I'll be doing to fix my problem.
Because of the location, is there anywhere in the passenger footwell that you could remove a small section of the bulkhead/floorpan to get a spanner on a locking nut? You could even make an access plate.
Edit: I guess this was what you were suggesting anyway...
Edited by cheys03
would tow the body round to a good machine shop and jack it up real high for them then they can do a helicoil insert if it can take the weight or re tap it and sleeve it back to the right size with the right material.
not really worth taking a chance on.
Edited by genesisGT
I think id cut a small opening in the floor to replace the threaded block like-for-like.
It may be that you could tap to M10 and use M10 bolts instead,but i dont know if the threaded block is big enough for this to be a great idea - quite possible it'd stretch open.
Then again,you dont have much to loose with plan B, if it doesn't last then you still have plan A anyway.
Think I've got a plan c now :lol:
Chop the head off a correct size bolt and thread it into the hole, weld it to the body then use it as a stud. It gonna be a lot quicker and easier than chopping out parts of the floor and should be stronger than trying to tap it to a bigger size.
Cheers for all the help tho every one :thumbsup:
sounds like a good plan too me if you can weld :)
