Engine repair
of the process..
To be continued
Edited by vjdzonny
  • Replies 21
  • Views 4k
Are purchased spare parts
Edited by vjdzonny
Looks good dude. All looks so awesomely clean
I try everything to be clean..
I was shopping .. :)
something from Germany
Edited by vjdzonny
First day
just a standard rebuild or you going for power increase ??
I believe that these engines are already powerful enough, the resource is not too large.
There will be a standard.
The project stopped, because of problems with valve grinding.
OH mate whats happened looking forward to this.
ditto.
new valve control
Last year..
AKACHI TEAM
Just now got the engine head repair:
Screw head engine
new compensator
new rockers
now starting to look after the engine
again was shopping
Restored to the front bumper..
Edited by vjdzonny
Maybe someone knows how to properly regulate the camshaft?
Everything is put on marks, but there is something wrong, because there is no compression.
before winter
A little bit of the process
engine installation
The first outing of the garage
sounds good
clean headlights
and
changing the oil and oil filter after the first 5000km
compression
speaker installation
and..
Last day with us is the air temperature dropped to -30
And unfortunately the engine at such a low temperature did not pass, observed a rapid oil-spill. :(
Colleagues I have a problem!
Oil seals can not keep oil.
Does not matter to install the new oil seal, the problem return.
Of course the visible surface wear.
I've been thinking about restoration, welding, and then refine it to the header size.
Maybe someone has faced a similar problem?
Any suggestions?
  • 4 months later...
after 6 month back to streets :)
Very nice indeed it just needs front GTI splitter and more lows.
  • 2 years later...
for sale
