Spraying splitter
Hi
My cars splitter has got scratches on it and i thought i would give it a good refurb and make it new again.
A nice guy off club polo (jordan eff) :D instructed me on what to do and here are his instructions.
ok what you'll want to do is this
you will need the following
240 grit sandpaper
400 grit sandpaper
800 wet and dry
primer and you choice of black
use the 240 and rub down the full splitter and the damaged areas till they are flat and smooth
once you've done the full splitter go over the full splitter again with the 400 grit and this will smooth it out more, make sure to do every inch of the splitter to avoid paint flaking later on
then apply 3 coats of primer to the full splitter then leave it to dry overnight. next flatten the primer with the 800 wet and dry till it is smooth and then yoou just need to clean it and degrease it and you can then apply the paint
But that was just to apply a black layer , i want to paint it relfex silver like my body work so do i NEED to apply a plastic laquer after spraying it silver?
And also What COLOUR primer do i need ?
cheers
  • Views 940
same procedure but for most silver paints i think grey primer is used but it should say on the silver paint can what colour to use
yeah i would apply 2/3 clear laquer coats after spraying silver
or....if you want the original textured effect you can use a paint called Plastex i think...
cheers buddy, how much laquer would i need and how much primer? 300ml each or 500ml each?
thanks
