side trim
hi, I'm wanting to remove the side trims on my car and wondering whats the best way to do it and will you be able to tell that it had them on after there off?
  • Views 652
They are just glued on so you can simply pull them off. You will need something like a toffee wheel to remove all the glue left behind though.
Also worth mentioning the paintwork underneath will be like brand new as it's not exposed to the elements so depending on the condition of the rest of the paint that might be noticable. Give it a good polish and it should blend in nicely.
thanks mate,
