Choke cable in a MK3
Been trying to figure out a place to mount a choke on a MK3 dash, just doesn't seem to be anywhere practical to put one.
Any of you guys out there running one in a MK3? if so... Where have you mounted it?
  • Replies 26
  • Views 2.3k
Dont be a pussy and hold it by hand until its ok to just tickle the throttle ;)
Fuck that man, you said it was a pain.
I wanna be able to get in and go, without the risk of the nice person stalling all the time.
There isnt. :lol:
I've got mine dangling by the radio in the passenger foot well. just reach over for it and then leave it dangle. Not found anywhere else it will securely fit too.
Ofcourse there's a suitable place for one, use your noggin.
Mines to the right of the steering wheel, ill get a pic.
Yeah, i have my immobiliser there...
Believe me, I've looked for a suitable place. I have a lot going on though on my dash :lol:
Sell me your electric window switches and put it there... :ninja:
haha no chance!!
I have my immob to the right but theres still plenty of space to mount one!
How about next to the fag lighter?
Really daft question, why do you guys have a choke installed?
leccy window switches are next to the ciggy lighter
And choke for bikecarbs
On the slanted part of the dash to the right of the wheel.
Thats the only place i can seem to find Max
I wanna hide a battery or fuel cutoff somewhere too. Just for if i leave it in a un-savory area or whatever. Hidden under the dash somewhere.
No point in putting a fuel cut off switch to try and stop people nicking it, the float bowls will still be full.
You going to bvf by the way?
Battery/coil cut off should deal with that. And the float bowls would just give them hope and would most likely get them about a 100yds. :lol:
I only need it for a split second to start from cold so haven't bothered to try and fit it somewhere properly.
If you can feed the cable passed the clocks there's the section to the left of them that might be suitable.
Stuck for inspiration,eh?
Use a central locking pump for the choke,and operate it by a spare switch under the stereo.
If you aint got a spare switch,do away with the rear window heater,its not legal requirement.
But its a polo requirement lol!
I fed mine through a little hole to the right of the battery, along with everything else :lol:
Not having a rear de-froster would be hell, especially when you have no rear wiper :lol:
I'll find somewhere for it. Possibly under the right air vent, pointing down a bit.
Not sure if theres room behind there though, Will have to whip it off to see whats there.
I've put mine in one of the blankers under the headunit.
A nice MG cable as its black and isnt very noticeable.
Dont know if you have something there already though???
Good call, just ordered one :D
Think I've found the ideal place for this, well hidden also :ninja:
Do you guys really need the choke.. I had one fitted when I first installed the carbs but I took it off as it really wasn't needed as it was never used.
Have got mine in the lower right storage bit under where the immobiliser is!!
Works a treat and doesnt stick out like a sore thumb!!
Will get a pic up later!! It makes sense once you see the pic!!
Don't really need the choke this time of year but come the winter when it's freezing it's
Sooo much easier just to stick the choke on for 15/20 seconds!! To help it start up!!
I guess it depends on the cars use as to weather you need choke or not.
Did you use yours daily through winter Mark? As i will be, and i can see it being a pain in the arse for the 1st couple of mins.
I'm in the process of doing something similar, I've opted for the blank under the stereo but I'm going to use a servo and a potentiometer instead of a cable... Fingers crossed it works though lol
This is where I have mine!! Might not be too some
Peoples liking but it works for me!!
Main reason for putting it there was because I didn't really want it on show too much!!
Rich
