PO-LOW MK3'S COUPE
Hello guys, just going to keep this short and sweet. This is the project log of my polo 1.3 genesis, i brought her off ebay with tax and mot, she ran sweet as a nut, but i wanted her as a project so i dint waste any time getting stuck in. I will let the pictures do the rest of the talking, if you have any questions please dont hesitate to ask. Have a look through and enjoy.... Thankyou Aidan
one picture when i went to have a look at her.
got her home and gave her a wash.
just a few pictures of the inside.
Engine bay once it had a good de-grease.
Started to strip her down.
Engine ready to come out.
Engine out.
Struts off.
Gearbox off.
Engine ready for strip down.
Got my hands on a GT head and cam. (striped down, ready for port and polish.)
Also brought some Thundercat 600R carbs.
More pictures to follow, i am also waiting to get my manifold back from bogg brothers for my bike carbs. I have orderd alot of new parts including: 80/60 lowering kit off philj on here, full gasket set, calipers, wheel bearings, piston rings, drive shafts + a few more odds and sods. I am waiting to get my struts back so i can paint them and build them up, plus i am waiting to get my manifold back so i can mate that to my head, and rebuild my engine :) as i say i will get the pictures up soon, thanks for looking.....
I think its about time for an update, been spending alot of time just recently on my polo, heres some pictures to show you what i've been doing...
Engine rubbed down and painted.
Strutts being primed up ready to be sprayed yellow.
Calipers being primed up ready to be sprayed red.
Crank casing after its been painted and had new seal.
Hub after its been painted.
Got my manifold back from bogg brothers and mounted it to my head (head is now skimmed and ports are polished ready to seat my valves.)
I will add a few more pictures soon as i'm assembling my engine. Hope you enjoy this update, comments welcome. Thanks aidan...
Edited by PO-LOW MK3
  • Replies 10
  • Views 2.3k
did you used to have a black mk2?
Hello mate from a distance it did look black, but it was very dark blue.
ahhh, ash leeke's brother yeah?
Yeahhh mate....
Right, a quick update, i got my piston rings yesterday and i brought a full mk2 polo ignition set to run my bike carbs. It wont be long now befor i am painting up my engine and re-building my bottom end. :)
I would get the head skimmed if i was you. Looks like it need's it.
Also, i wouldn't do much porting on the inlet ports, just make sure they're all nice and smooth,
Porting them too much is just going to decrease gas flow velocity up to the valve,
The best thing you can do is make sure the small side radius beneath the valve seat is smoothed off as there is a nasty casting flash mark.
Nice work!
Updated ;) :p
it your doing it as a project and fitting an 80/60 kit
i have some advice
1 lower the steering arm on the front suspension strut so the track arm will sit near level when the car is on the ground
although for that work some might say make coilovers,its up to you
2 raise the engine a bit to take the strain off tour cv joints and make the drive shaft more level. other than that keep it up mate.
I'm lowered 80/60 and have no problems with drive shafts or steering arms nice progress bud keep it up
You dont hang about do you :lol:
great progress :thumbsup:
