Small rust patches
Have always wanted to get rid of the tiny rust spots on the car on the bottom sill. It is only surface rust, and it is really small, but it is really annoying and obvious once the t-cut has worn away! If I buy the correct paint and primer and lacquer etc, do you think I will be able to sort them out without it looking ridiculously stupid after? Like silly little white patches after it's done?
Dan
  • Views 936
Well if it's only on the sill is should look alright. I take it it's one of those problems that bothers you that nobody else would notice?
only problem is what could be a pin spot on the surface could be 50p sized ones you start sanding back.
On my spare bonnet there were a few small spots but there was a lot more rust under the paint/primer than showed on the surface even where the paint looked perfect.
Is indeed one of those annoying things that I notice! I will be sanding them down treating the paint too
