Mk3 cl gearbox
Looking for a replacement gearbox for a mk3 cl, 5 speed
Midlands area only, what have you got?
Pettsy
  • Views 754
hi if you struggle i have a 4 speed box with drive shafts located in trowbridge going cheap
Pettsy
I've got one from a mk2 polo if that helps? Jon
I've got a mk2 polo coupe s 5 speed gearbox which think is same could do with a diff bearing but goes through gears good easy to do are diff bearings
I allready have a 4 speed as a backup but would like a 5speed i can bolt straight in with no known issues.
