6n2 gti splitter
just a quick one how do you remove the gti splitter theres one up the scrappy but he wont remove it for me :x so i need to know just so i dont damage it, am i right in sayin it just clips of ?
  • Views 2.5k
is it on a gti mate if so am sure it just clips off
it might just clip off but if not there will be a few 10mm bolts on there
two screws one eitha side of wheel arches connected to it uncred them then get under the bumper and there is clips behind it....tricky clips thou lol they are annoying
cheers guys :thumbsup:
pain in the ars take the bumper off and un clip as many as you can and pull un cliping as you go, its got loads of flex you'll be fine lol enjoy
Take something like a thin strong plastic trim remover tool (someone to help aswell).
from behind the bumper you need to work your way from one side to the other, undo the screws on either side of the bumper inside the wheel arches which attatch to the splitter.
Poke the trim tool between the bumper and splitter from the front/outside of the bumper and try and aim for the holes where the splitter attatches to the bumper, if the clip is released then try to pull the splitter forward and hold it (or get a friend to hold it for you) and then repeat for the next clip while holding the splitter away from the bumper until the splitter is free...
Pain in the arse when putting on if you dont get it central!
i would say for the time and stress of taking one off (if its not been taken off before) plus the price of buying it i would just get a new one.
