Mattie's 6n Polo 1.8 20 Valve Turbo Project
What handbrake cables have you used? do they go to rear disc set-up?
Running a Polo gti set up and have to use the polo gti cables. I had to get the clips that hold the cables onto the caliper too as my set up didn't come with them. Only a couple of quid from tps ;)
  • Replies 501
  • Views 103.7k
  • Well its been a hell of a long time since I've updated this build thread! So lets blow some dust off it and get up to scratch! First of all the start of this year we again moved units but th
  • Okay been a long time since i updated, been far to busy trying to get my stupid 22 year old body in shape for a lads trip to Zante in july but then trying to balance that with drinking, smoking, havin
  • Got the rest of the passenger side boost pipes on today with all new clips and connector hoses. Then when round the bay and did a thorough check over to see what I had forgotten. 20160610_145104_
Okay sound. Do you know what the cables cost new? either from tps or vw?
Got mine from VW TPS, ill have a look later mate. I keep all my receipts, think they were like £20ish but ill double check ;)
6N0609721M - £9.64 each ;)
the joys of having ETKA at work
Joys of working for VW :-( iirc? :lol:
nah, Febi Bilstein... ;)
if i worked for VW id have ELSA and be able to sort my shit wiring out hahaaa
:lol: Elsa? the cleaning lady thats doing it in her retirement? She that good?
Bilstein ayyy, dare i ask what shocks your running :lol:
I'm ashamed to say weitecs at the mo :(
started work here after id bought them, we dont have anything to do with the shocks here though, bilsein and febi are a different company
still get a hefty discount of some though if i want them ;) PSS9's are on my list of things to buy though hahaa
yeah elsa's a handfull, but shes up for anything ;) ill put in a goo word if you want ?
ASHAMED TO SAY! FUUUUUU! best sell me your embarrasing setup cheap given it is embarrasing when you done ye. :lol:
Stop clogging up my thread girls! I have ETKA at work too ;) but its last years so its a little outadate on prices but there near enough :)
But I've got a trade account set up at TPS now so makes my life easier can pay card over the phone and get it delivered for free to my unit! WOOP!
Started trying to pipe up the vaccum and coolant lines today cant remember for shit where they go so printed off the layouts on ETKA and all the pictures I've got of the engine before i stripped it down...epic fail.
stop crying and get on with it ;)
me and harry are gonna finish way before you at this rate, and i thought i was behind :lol:
Matthew here keeps getting pissed and throwing parties :x Like the homo he is.
I think you both will be but i dont care, mines all easy stuff from now on. It'll be all piped up by next week, all brake hoses done. Just waiting on my painter...
Haha i LIKE ZEE BITCHES BRO!
I'm getting there so get off my back ;)
Josh we might be able to give him some motivation to crack on ;)
I have motivation, I've been on it all this week!
It will have moved on alot by the end of next week.
Thats a promise...and not one from AsDa.
Chaps, on a serious note. Do any of you have trouble with clearence to your Brake Master Cylinder? Mine sits directly to the side of the cam pulley and i have literally 2mm clearence. I know this isnt going to be enough, what i want to know is there a different cylinder i can fit? I.e. one thats and 1" shorter but has a bigger diameter so i can keep the same pressure? My mate said something about a Fiat one thats available?
or a relocation kit?
Any help would be appreciated.
cheers in adavnce.
Edited by Mattnaz
Sorted my master cylinder issue... Seat did a stubby version on the Mk3 Ibiza Cupra's and its bigger at 23mm ;) just got one off the bay fully working for £18!
Boom.
Boom.
not that simple :) i use the same one...you need a spacer about 4mm in thickness because you'll lose braking efficiency otherwise.
When you bolt this stubby MC to the polo servo, it will start to depress inside as you tighten the two 13mm nuts...to stop this, you need a spacer between the servo and the MC with a gasket made of rubber to seal them all together (not sure if this is 100% necessary but i'd rather not risk it without it).
Boom.
I knew this ;) actually did some research for a change but from what i read it was a 3mm spacer? ill be making one at work anyway, if the 3 doesnt work ill make another :)
Thanks for the heads up though Sanj :thumbsup:
3mm gasket and 2 thick card gaskets, 4mm all together maybe?
Edited by POLOMON
Probably I'm pretty sure that if i make it thicker it would be better than having it too thing. So thinking 3mm spacer plate and then 1mm gasket paper either side ;)
Got some work done on putting all the pipes back on the engine yesterday and figuring out where I'm going to put my intercooler piping etc...
Had 2 of my tyres taken off so i can get the wheels to the powder coaters for a lick of satin black, then going to get my tyres fitted up.
Also bough...Full 2 1/2" Intercooler piping kit, SAAB Red Injectors, Ibiza Cupra Stubby M/C and my stainless for the exhaust has finally arrived :)
No pictures unfortunatley.
there is another way to do this...check this out:
http://www.clubgti.com/showthread.php?248164
Most will now drill down the MC to get the 3mm clearance instead of the spacer...next time i do this, i wont be having a spacer made :oops:
I did wonder if i could do that, but thought that if no-one else had there must be a reason.
New plan cheers Sanj ;)
Right seeing as it payday tommorow I've ordered a few more bits to use up my leftover cash :-D
-25ft of Kunifer Brake line
-Goodridge Stainless Braided fuel lines and aeroquip fittings (going to weld stainless fittings to the fuel rail to fit it all)
-Goodridge stainless braided brake flexi's
-All fittings for brake lines
-Brake adaptors currently down at the machine shop being made for the end of next week (lazy backhanders...)
Received my SAAB injectors yesterday so taking them to a local shop for electro cleaning so they are perfect.
Not got my intercooler kit or Seat M/C yet though :(
Okay couple of pictures of what i did the other day...
Started to put some piping back on but got bored and fed up, plus most of the pipes need cleaning (blasting) and then painting, but got the intake on and the after turbo pipe. Ill be moving the after turbo pipe as i cant run my hose down in front of the alternator due to clearence issues... so I'm going to be cutting it off where it bends and re-welding it so i can run the piping down the wing and into the front bumper.
WP_001404 by mattnaz, on Flickr
With the slam panel on and the rad in (got a new rad for it so wont be using this beat up one)
WP_001405 by mattnaz, on Flickr
A rough cut out of where the inlet sits in the slam... and this is how I'm running my throttle body. Only way i can run it with being able to shut the bonnet :? Hopefully it wont cause any issues...
WP_001406 by mattnaz, on Flickr
Then got bored and ate this...
WP_001401 by mattnaz, on Flickr
Oh and went to see Batman last night...SO EPIC!
More updates next week.
