Vw Badge on boot.....
I've got Polo 9n2 and I'm just wondering whether the badge is stuck on by an adhesive foam or if it is held in by pins? need to no so i can safely remove it you see.
  • Views 927
I'm positive there all stuck by sticky pads. I think its only the models with the boot release under the VW badge that are different but I'm not 100% sure! lol
Yeah there stuck on with pads i done work on a tdi model and removed the badge that was a sticky pad, if i remember correct tho, theres an identation behind the badge
Ok, thank you both for your help :-)
