Smoothing bootlid badge
Could i simply just fill, sand, primer etc to smooth the hole that removing the boot badge would leave
  • Views 979
i would spot weld a piece of thin sheet where the badge would be, filler,sand,primer spray
I just fillered mine been done a while now n hasn't cracked or anything..
Oh it will :)
martyn your lucky.. I've seen stuff that are mm thick crack.. not a whole inch like the badge recess
Defo weld a little plate in it will save you time later
Thanks guys, someone told me to use a body filer called isopon metalik as its basicly a metal compound when dry, is this true
