Rear wiper problems
I am having proplems with my rear wiper.
It originally worked then recently it wipes then stops at a certain place. After wrigling it it works again and stops at the same place again. Now it is stuck in this place and wont work even when wrigling.
Any help?
  • Views 753
de-wiper :D
Well id test that the motors ok and it has enough power. and maybe grease all moving components to make sure its free
You may also find that the motor brushes and/or commutator are worn. You may be able to clean up the commutator and replace the brushes. Make sure that the brushes/commutator are free from oil, grease or dirt etc.
Regards.
