WATER!
hi, all just wondering if you could help me out here! as its gotten super hot in the last couple of days, i got in my car and notice that the clothes that i had left in the passenger foot well where completely sodden, so i pulled up the carpet and noticed that that whole foot well was wet and it looked like damp, i checked the door seal on that side and looked in perfect condition, i haven't had the polo long so dont know if its a problem its had in the past??
any solutions???
  • Replies 12
  • Views 1.5k
What car is it?
One thing to do it to sit in the car and get some one with a hose to hose the car down and see if you can trace where its coming from.
If it is a 6n like mine i think it is comming in were the pollen filter bace is (the bit that holds the filter in with the fan under it ) it is located in the scuttel pannel on the passenger side were most of the water goes (from windscreen) then the water gathers up around the plastic bace and slowly drips in
iv been helping a mate doing a engin coverstion and his ibiza and his floor was wet we had to take the dash out to sort the loom out and located the leek to the same spot
hope this helps :)
If its a 6n then like said above it will be the pollen filter area, make sure there are no leaves ect in the scuttle as that will cause the drain holes to block
:crybaby: my 6n had a huge water leak which flooded hole car. Investigated and found it to be some wolly had fitted after market alarm and push siren wire throught groomet for rear wash pipe in bulk head hole so was kkinda an oval shape and was pissing watter in. Silicone up like new lol
hope this helps :)
thats awesome yeah it is a 6n bit of nob not to put it in completely forgot! haha i'll go check it out and get back to you thanks very much guys!!!
If you don't clear the leaves and crap out then this is what happens. This was a car we bought at the weekend. It is a P reg and still had the original factory pollen filter in, in fact there was so much leaves, sticks and mud that initially I couldnt even see the pollen filter.
Dont forget to check the area in front of the driver as well. Once you have cleared both sides make sure you run the hose down the drain holes located close by to flush them clear.
Edited by BRABUS
wow that doesn't look great!
i checked the pollen filter last night and was clogged up with still the original filter on it, so i have cleared that and going to give it a couple of days for the water to clear out completely and see if it has worked.
hi, guys the bloody water is back it looks like condensation if that helps and i pulled all the carpet up on that side and it seems to get dryer the closer it gets to the dash, i have cleaned out the pollen filter but it looked fucked so i am going to buy a new one but there didn't look like there was any blockages i twisted the little thing inside, and turned easily enough?
I'm stumped but still hoping its the polen filter i will get a picture and upload when I'm back from work might give a clue?
You will get dampness for weeks even after you sort the pollen filter out as those carpets and sound deadening can hold a lot of water, we got almost have a bucket full out of ours.
The best thing you can do is take the carpets and sound deadening out to help dry them, it really is quite easy. This will also help you spot if you have any other leaks whilst the carpets are out :)
Edited by BRABUS
Mine has a problem like this, one thing wrong was a small gromet in the chassis was missing, but once that was done I noticed passenger door sills were pretty perished and there was a small leak of water coming in in heavy rain.
I'm going to check my polen filter when I find out where it is???
Its on the passenger side. Pull the rubber off that goes across the top end of the engine bay. you can then carefullly remove a piece of plastic that goes across the scuttle under the windscreen. I don't have all my software installed at home to be able to show you a diagram.
I did find this video on YouTube but it's a mirror image of a right hand drive car.
On a polo you dont have the screws to remove, instead there are 2 clips that are under the rubber at the bottom of the screen. I have never managed to get these out without breaking them but I have never bothered replacing the clips afterwards either with no ill effect. The rubber at the bottom of the screen will pull off and is easy to push back in place afterwards.
Edited by BRABUS
yeah i think i will do that it doesn't seem as bad as what it was so must be working!!
