Is it just me...
That misses coilovers?
I came from a mk4 polo with coilovers to a mk3 polo with springs and shocks and i just hate the fact they dont adjust (apart from the rear), they are a set height and they seem bouncy compared to stiff coilovers.
I know you can buy coilies for these models but they cost the earth compared to ebay jobbies for mk4 +
I know its personal preference but does anyone else feel the same or do you actually prefer springs and shocks?
  • Replies 9
  • Views 1.4k
It's to do with the strut and hub assembly, it's all explained in a thread by philj.
There are ways to get cheaper Coilovers such as using mk1 golf setup but whether you have the time or skill to do this is a different matter. Shocks and springs are fine, but like everything, you get what you pay for.
Coilovers would piss me right off.
The standard struts with hard dampers and fairly short springs have been too hard for me - i dont favour the reduced performance,poorer fuel economy and premature wear/damage to components caused by the car crashing over bumps.
How does the ride affect fuel economy?
I'm not fan of the stiff ride either, give me comfortable any day!
Going on the brakes to avoid smashing the floor and accelerating back up to speed, I would imagine.
But the lower a car is the better on fuel it is on the motorway. IIRC it was Eibach who were using the increase in economy as a selling point for lowering springs lol.
The more the shell fidgets,the more energy is being used to throw it about,therefore the more momentum its scrubbing off. Softer suspension allows the car to continue without so much absorbing energy,as the wheels raise up and down to follow the contours of the road and the car is more isolated from the high friction surface.
Additionally,too much rake (positive or negative) also uses energy,as the air is either trying to lift the car up or push the car down. So for aerodynamics you want the front and rear of the floor to be level.
There is also the major factor as said above,that the driver of a lowered car is having to compromise against an economical driving style,when a more softly sprung vehicle can comfortably have more consistent speeds sustained for longer periods.
Only one factor can make lowered cars use less fuel - a car is more aerodynamic the lower it is. But for this to be useful,you'd need to be driving on Germany's glass-smooth roads like Eibach were. Here,that benefit is usually offset.
I'm sure the impact of suspension upgrades is minimal which ever way you look at it
I love my stiff coilies, currently driving my mk2 on -40mm eibach springs and koni dampers and it feels like a boat compared to the mk1 coilies :lol:
Skip... I thought it looked quite tidy from the pics you sent me?
