Mk7 Polo Advice
Hey guys,
First post I've had on here, but got a few mates who used to be or are still fairly active on here, samgt and R16HNW ayone?!
Anyway, looking to get a Mk7 Polo, and seen a 1.2 S for a decent price. I'm not fussed about all out speed and need something that will be relatively economical. I do about an hour RTT to work everyday on country roads and will probably do the odd long motorway stint once or twice a month. Reckon the 1.2 will be okay and won't be screaming down the motorway in fifth? My current car (a freebie!) is something old, cheap and Korean with a 1.0 engine so anything is going to be an upgrade to that!
But yeah, the car itself is in good nic, little scuff on the n/s rear arch but nothing disastrous. I was ideally after a Mk5 Golf, and started looking for a diesel but not sure I can justify the extra money to buy the car in the first place at the mo.
Anyway if anyone has one or anyone has buyer advice on the Mk7 in general let me know!
Thanks in advance!
tried a mk5 polo tdi?
perfectly good cars
There're a lot more 9n/9n3 owners over here:
www.uk-polos.net/
We've got a 3 cyl. 1.2 9n... It performs better than it really should (considering weight and lack of power!) and motorway cruising's fine... As with most "underpowered" cars, it's accelerating from 50 that's the killer... Pushing the pedal harder makes more noise, but doesn't really seem to aid progress!
Economy's not all that... Probably averages 30-35 to the gallon - better on a run though! It suffers from the "small engine being pushed hard" factor - I'd anticipate you'd find a bigger engine's better on fuel.
Silly thing to check when looking for one... The rear washer jet should squirt up the middle of the screen - not follow the wiper arm. If it follows the arm, it's broken, and will leak into the boot.
Ours is on an 03 reg, and still on original exhaust, shocks, springs and all bushes except the "console" bushes. (Tyre wear on the inside of the fronts shows they're on the way out - nightmare job to change yourself, and the seat cupra bushes are apparently much better!)
If you get a TDI the MPG can be good
Somthing to consider
I have chipped mine and i can get around 55 - 60 mpg on motorway routes
Town driving carefully i can get 47 > 50 - to my girlfriends and back if i go really carefull - I can get there with 60mpg average displaying on the clock and back it ends up about 58
And for me , its pretty niffty too
Edited by mpsheen
after a quick look on autotrader you could buy a 6n2 1.4 16v 100hp like mine for between 30-50% of the cost of a 1.2 mk7 and it really is a much more capable car and in the real world get better economy and be able to keep up with most traffic will go on to nigh on 120mph, official figures are Fuel consumption (urban) 28.8 mpg
Fuel consumption (extra urban) 52.3 mpg Fuel consumption (combined) 40.4 mpg. I also have regularly got 53mpg out of it on a run I could get more but then it'd take longer to get places.
Plus 100bhp Polo are alot of fun..... :D
Don't forget there's 2 versions of the 1.2 3cylinder. Think one is about 55 horsepower and the other is around 69. 4 valves per cylinder and all. Seeing as the fuel economy of the 3 cylinder engines isn't great anyway may aswell try and get a higher powered one.
