polo 6n speakers
just woundered if its chavy putting speakers in parcel shelf.? they got grills. i dont want to ruin it. were does everyone else put speakers in polo 6n?
none in the back
  • Views 1.3k
tbh i dont think there chavy, iv got some in mine but there hidden. I think its better with them...
anyway its you are car id say do what you like :)
its not a case of being chavy, its what it sounds like. i have pioneer components in the front doors, with two subs and a hidden amp in the boot.
only ever had good comments, and all my mates say its the best they heard unless faced some mad demo car at a cruise or show.
speakers on the parcel shelf look better darker so you dont notice them as much. but if you have a sub/subs in the boot you may find a bit of distortion from the speakers on the shelf. This is cause by the the amount of air displaced by the subs in the boot.
tbh for good high quality music all you need really is a good stereo, some component speakers in the front doors and a sub in the boot powered by an amp. its not about quantity of speakers its the quality of them.
if you still wish to add speakers to your shelf there is a way to stop distortion. "car audio security" sell 6x9 boxes these can be screwed to the bottom of the shelf giving the speaker its own enclosure. these come with there own problems, they look unsightly and may cause clearance issues with the top of the subs. meaning when the boots closed the parcel shelf might end up raised a little higher than it should.
hope this helps.
Well its your car and only u can decide how u want you are car, do u want to follow a crowd like sheep and b called names cuz u haven't the latest rims or the lowest car? Its your car, your pride and joy, dont b scared to try different things u never know people might follow,
If you want To do something and want different angles on what to do with it or how to do it is different :D
I haven't done it my self but if your planning to do something different and dont want your speakers to look "chavy" then look at a different angle... Stealth shelf? Or get some material to and cover the parcel shelf...
On mine i haven't the 6x9's but i have covered my parcel shelf in check material which goes with the theme of my car and gives you are car a different look :)
Hope this help in your future choices matey
How can you even remotely say that speakers on rear shelf are chavy....
Main reason people dont do it is simple that the pressure given off By the sub effects the rear
I ran 6x9s in my old punto (hangs head in shame) and powered an amp to them, alone they sounded like a sub with the plus of all my boot space :) people imagine 6x9s with chavs as they asociate quick stick it on mods to chavs, and bodge jobs, 6x9s done proply dont think ull risk been called a chav just dont put the speaker stickers on you car and have a catalog of what you got in you car on the side! Lol
Keeping my MK2 looking totally standard is something I'm highly conscious of. It may be fast but even the tailpipe is a standard galvanised 45mm pea shooter.
My stereo is nothing to write about,a twenty year old 4-speaker factory job from a Honda. But how does one make the speakers look stealth in a car that only had provision for 4x6s?
So there's a pair of 6x9s in the shelf. Now hiding these has called for some philosophy. No good using acoustic carpet,as it'd look too good in comparison to the coarse cheap-looking carpet that came as standard.
So the answer is to fit grilles that i like. Some plain ones from an '80s car,in fact.
They're small and round,but that doesn't matter because you dont need a 6x9in hole to fire a 6x9 through.
As the 6x9s are only a basic 2-way design with the styled plastic trim removed from the tweeter,it just looks like an old pair of 13cm 2-way's are under the grilles.
x2 Keeping a balance between standard and personalised is kinda' difficult.
