6n2 wobbly window and squeaky seat...
Right so my 6n2 has had a wobbly window since i got it and its really annoying, whenever its down it just knocks as I'm driving and if someone shuts the door it knocks about, how do you tighten it up????
And the passenger seat has developed a squeak, sounds like the springs in it are dry or something... anyone know how to sort this????
Any help will be great :D
  • Views 1.5k
It's charceter !! To fix the window wobble just remove the door card & tighten down the two 13mm bolts where the window sits in the reg
haha not when you have to put up with it for a year! Thanks for the reply! :)
the seat will be an easy fix too, just needs replacement plastic guide runner on it. Slide the seat right back and you'll see the white/yellowy plastic bit at the centre at the front.
HERO! haha thanks man will look at that now :)
Right with the window, i cant find the 13mm bolt too do up! :( Where abouts is it???
Once you have removed the door card you should be able to see where the window glass sits in two little rubber clamps in the reg you might have to wind the window down to be able to see both of them just takes a bit of tinkering
Okay thanks man will have another look :)
