Regal Autosport - Camber Shims
Camber/toe correction shims for most rear beam VAG applications.
The shims fit between the beam and the stub axel, adjustable between +1.5 degree and -1.5 degree camber with additional toe correction depending on orientation.
Easy way of correcting toe or introducing negative camber ;)
These have been cut out for a 6N2 Polo GTi (rear discs) but will fit drum setup as well, the top bit that has been cut out is so they fit around the ABS sensor, but this is the flat side of the shim so will no matter anyway if your after camber
£12.50 posted for the pair 8-)
  • Views 377
SOLD
