Wanted: Mk3 alloy wheels bolts
as title, I'm not sure of the exact size, hoping someone will know :) cheap as possible please!
thanks
Edited by richoco
  • Views 607
do they need to be longer or standard ones fine?
bummp
standered bolts are fine
if you are running 13x5.5J then standard mk3 bolts will be fine.
yep the above is correct you can use your std studs of your steels if your running on 5.5j as the seating should be the same cupped as opposed to tapered
oh right cool that makes life easier.
so these bolts that came with my mk3 gt steels will be fine on my bbs ra's?
thanks
