085 gearbox which bolts?
Right just a quick one as i haven't kept my transmission bolts seperate and have become mixed in with a load of others can anyone tell me or show me which bolts are used to mount the gearbox to the engine i have a vague idea but need to make sure so i can torque them up correctly. I need length, size and thread if possible or even a ETKA diagram should have pictures.
Cheers.
  • Views 979
you tried vagcat?
Just had a look on it actually and there on there but theres two more than i thought on it so would like to know from someone with experience to be 100% certain.
They are 19mm headed M12 bolts, about 60mm long with half of that length threaded :)
Torque setting is 55Nm
There should be 5 of em too
Edited by Phataz1
3 go from gearbox side into block 2 go from block side to the gearbox.
