Mk2 battery tray repairs/renewall
Got a pritty big hole in mine with needs to be done for the m.o.t
whos done there recently WITHOUT welding it?
pics would be great with a list of what you used etc
cheers :)
  • Replies 10
  • Views 1.6k
Cleaned up the area and siliconed a square cut from the lid of a qualitly streets tin...... It stops my feet getting wet :lol:
Dont bodge it dude, unless your getting in welded after.
You'll just end up with a nasty mix of silicone and paint when it comes to fixing it properly.
is it a mot fail then ? if so only welded repairs are acceptable
as above. It's within the distance to a major suspension pickup point that requires any repairs to be fully seam welded for the MOT.
However you'll get away with bodging it if the tester simply doesn't notice a repair has been done or if they can't tell if it's been welded or not because it's caked in underseal.
So its defo and m.o.t fail then..
i got welding the do on the sill on a tiny bit so might get round to welding it
but if not just looking for a quick fix till after m.o.t really
I'm thinking fibre glass over it smooth it down and paint it
but also the bolt that you use to clamp the batterys not there so tht needs sorting as well as its defo a m.o.t fail to have a lose battery
might as well bite the bullet and do it once properly
TBH it shouldn't cost much to weld it up :)
Last i heard it was a advisory...?
dont bodge it, ill weld it up
i was,nt gonna bodge it :lol:
it will be preped as soon as my old mans out so i can use the grinder :lol::lol: Cock!
