Polo GT- Complete Engine for Sale
for sale a complete gt engine convertion with engine, gearbox, starter, alternator, manifold, loom, fuel pump, ecu
loacted in Heston, West London
£170
A courier can also pick up however you will need at arrange this.
Puneet- 07955957515
  • Replies 13
  • Views 713
sell the ecu seperate??
hi what mileage is the engine on and does it come with everything you need for a conversion
thanks ash
Yes its everything you will need it plugs straight into a 90 spec fuse box, the mileage is unknown
I have clocks but don’t know if their reliable as it’s in km and from a European import jetta
sorry not splitting
Did it run okay? No oil leaks or anything?
Is it original GT box with short ratios?
Any pics?
It runs perfect, it does not have a gt box, it's a 4 speed box as it's from a jetta coupe
I might be interested can you actually be clear on what is for sale though? If its out of a jetta, would that not make it an NZ (55hp MPI)?
the jetta was actually a import and I believe it has a gt engine but I am having trouble finding a engine code, I can upload some pics if it will help identify it.
Please.
yeah i'm intrested some pics would be good
There not very good pics as the engine is stored in quite a difficult to reach place, but if you require more, please just drop me a pm from which angle and I should be able to get some more.
Edited by Punz
Looks like a nz to me, has a vac advance dizzy and the plug on the throttle body is similar to a g40 one , also if you still have the coil it will have a 6 pin plug on it, cheers Mark
sorry guys is actually a nz engine code so 55bhp
£140?
