Passenger electric window not working?
Just wondering why one would be working and the other not?
Switches? Motor?
I don't know but I know it's a common fault
  • Views 861
First try swapping the switches over from left to right. If this works then you need a new switch.
If that fails then try operating the switch whilst moving the rubber wiring cover that goes between the door and the body. Polos wiring breaks in here over years of opening and closing the door. If it works when waggling this then you can usually get away with some soldering and shrink wrap to fix the break (more likely several breaks).
Cheers mate I'll have an attempt at the weekend
