Electric window mystery
Hi guys, got my passenger window and central locking finally fixed.
my driver's side window has proved to be a pain.
I've changed the motor, the wiring loom, the fuse and still nothing. I hear the window make a click sound when i press it but it still doesnt work.
I eliminated the problem with the motor being faulty by checking it with the other side.
The wiring loom worked fine with everything else.
Any ideas?
  • Views 802
You say that the wiring loom works fine, but does it work when under load? If there is high resistance in, say the door multi-plug, you may still get enough voltage at the motor, but not enough current to operate the window under the weight of the glass/friction in the mechanism.
Regards.
Probably has come off the regulators, often happens when you slam the door, have you tried the switch? The contacts in mine were really corroded, changed the switch and fixed the window itself onto the regulators with a washer and nut combination and now works a treat.
  • 3 months later...
My passenger elec window gave up some time ago ..however it does activate by its self some times. Now drivers side is playing up..wont open.. any ideas plase.. ( it will open with persistant action on control) Polo 02 ..Thanks.
