My car won't start! :(
Hi, i have a polo 1.4 S 8v 6n2
when i turn the key to start the car after ignition, all the lights go off and u just hear the chunking noise and it just wont start.
i have a start stop button in the car though and when i try start it from there; it works fine.
any ideas?
  • Views 882
Does the interior light go off/dim as well ? Can you describe "chunking" a little more for us please?
Interior light is fine, the normal chunking noise that u hear when u start a car. But in my case the car won't actually start; it just keeps going ''chug chug chug'' and the ignition lights all turn off when I'm doing it. But the second I let go of the key, the lights come back onto ignition. The only way to start it is to put the car in ignition and press the start stop button.
I'm thinking something to do with the ignition barrel maybe? Expensive? Cheap? Easyfix?
New battery?
Possible coilpack/ht lead problems aswell. Can you check if you're getting a spark?
New battery?
surely its not that because when i put it in ignition and use my custom "start/stop" button, i can turn the engine on without any problems.
Ah well, maybe the ignition switch then.
Unless the way you'd wired the the button is interfering somehow.
can't be that, i've had the button there for a year :lol:
